daveypower
what sort of issues would you run into if you did the above? or is it perfectly ok,
Hi daveypower, I've done this a few times without problems. Hope this helps!
Theres a very good reason 0.6 nozzles are made
The general rule of thumb is use the correct tip for the wire size but the next size up will often do if you're stuck.
Obviously, the next size down doesn't work too well.![]()
