Afterimage
- England
I know that 0.6mm wire is recommended for thin panels etc,but if my welder (Esab Origo 170A) is loaded and set up with a 15KG spool of 0.6mm wire,can I just crank up the wire speed and amps and weld heavier steel?
Or should I change to 0.8mm wire for the higher amp welding?
