I have a NuTool 255N Mig, I always used to use 0.6mm, but now it keeps arcing back to the tip.
Wire speed 5
Power 3 (out of 8, or is that 16?)
Weldpool CO2
I'm having to use 0.8mm wire instead, which is a bit heavy for car bodywork. Has the wire supplied got softer over the years, am I doing something wrong or has a fault developed in the Mig? I know that the steel supplied is softer as you cannot get Automotive Steel "like wot you used to get".
There are two Earth points one the unit, am I correct in assuming that one is 1/2 the power of the other? The Torch plugs into a thrid socket for reversing the polarity. I had a problem previously where the tube that takes the wire to the torch had worn and kept sticking.
Richard welding up old Triumph cars.
Wire speed 5
Weldpool CO2
