The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
I created it in the Cricut software. It doesn't let you export it, or I haven't found a way yet!Could I have the file for that please?
If you just need a couple then I will make them for you. PM me your address.Ah OK. I need to make some signs up for the boat. I was going to print some, but if yours are vinyl they would be much better. How do you feel about me buying something suitable from you?
Steel washers around the part also add to the holding power.I made a couple 4mm half nuts, crazy right?
It's my little "surface grinder" setup on my Tool and Cutter grinder, it works for me! I have found by using a couple offcuts of plate/sheet I can hold small stuff in place really securely.
A filler cap.
S shaped tool to make the o ring groove.
4mm pitch thread check, run away from the chuck.
That's the thread done.
Knurled with a support as I didn't want it coming off the jaws with the side load.
And finished, now to make the surround.
I don't have the app, I only have the software on a Windows laptop that isn't associated with my phone.You can on your phone. Go into projects and there's a share button.
I am glad you are getting some use from itCarrying on with job avoidance this was a nice quickie, picked this hydraulic table thingy up from @My Old Landy ages ago, to make it more useful it wanted a top
More random bits of timber
And a coat of something harmful to nuns&kittens got it oil resistant, lifts off easily when not required
Just need to make sure it doesn't get stuff dumped on it
My mistrust of Microsoft runs deep!
And the very Best of British with that ambition!need to make sure it doesn't get stuff dumped on it
That's a good shout, I can do that for AJMy lad somehow manages to import pretty much any screen grab image, be it PDF, JPEG, PNG etc into Fusion after converting to a DXF and creates a printable model from it:
