normspanners
As always it was a last minute decision to fit it over the weekend coz they had a new pumped pressure wash bath in with a window air curtain cleaner using about 15cfm and were expecting a little 1ph hobby compressor to run it !!
I had two to choose from and yep picked wrong
but the oil pressure is up in mil secs so might not help but then would effect the normal running !and yes I had thought about pre filling too !! even 20psi would work IMO but I am working with someone (THEM) who wired up a 3 ph machine and copied the 1ph lift wiring, that was running off 5pin= 3ph +n+e plug using 16a 1ph and wired the 3ph blue to neutral and worse the yellow ph to the earth pin along with the earth cable !! and blamed the machine !! saying it was not working and could not understand how a 1ph machine was wired to a3ph plug !!
