Thank you, but this is a website to buy nozzles right? Bright spark had already linked me to one :P What I was asking is if there is any rubber piece that will fit inside my 1/2" ball valve so the gun doesn't jam when it get to the car spark plug because it liks a 15mm hole to 3mm and the abrasive just jams in there and stops airflow
I am not using the ball valve at the nozzle to regulate the media like you said I am using it to be on or off. But that ball valve is 1/2" and the ID is more than 10mm when I fit the car spark plug (as nozzle) the hole is like 3mm and the media gets jammed. I can send photos if you want because i am not able to explain it, I needed like a rubber piece to reduce the diameter so it didn't jamIf you're using the ball valve at the nozzle to regulate the flow of media you haven't got the pot set up OK, it should be either on or off.
Turn all your valves off
Open the nozzle valve fully (if fitted)
Open the top air valve fully
Open the valve at the side fully
Slowly open open the bottom valve until you can just see the media stream coming out of the nozzle
If you want to reduce the overall air/media flow adjust the top valve (or the regulator if you have one fitted), and adjust the bottom valve if necessary.
It can take up to 15 seconds for the adjustments to take effect, so be patient and adjust the valves a little at a time.
I am not looking for nozzles :P (but thank you for the tip) I am looking for something to reduce the diameter inside the ball valve to fit my 3mm nozzle like a rubber pieceI used to make them with cast iron window sash weights. Turn to the size you want drill hole you need down centre heat to cherry red then put compressed air down hole till cold enough to handle, don't water quench. These are harder than carbide and last longer. I had to do this when I forgot to order nozzles for a large industrial walk in shotblast unit. I only made them as a temporary fix till the carbide ones arrived but the cast ones lasted at least four times longer than the carbide ones.
MBB
Ok so I would control it from like the quick connector valve/near the pressure regulator/water trap valve (in your case it is not a quick connector), right?here's both of mine I've been using them for 40 years no problem
yes I use c couplings on both mine with large bore hose but if your using a 3mm jet a 10mm bore pipe will be fine using slightly larger bore connectors than the standard pcl couplingsOk so I would control it from like the quick connector valve/near the pressure regulator/water trap valve (in your case it is not a quick connector), right?
Thank youyes I use c couplings on both mine with large bore hose but if your using a 3mm jet a 10mm bore pipe will be fine using slightly larger bore connectors than the standard pcl couplings
namely 90cfm I use oneyou need loads of cfm even for a 6mm nozzle
