mart
- South Yorks
I’ve owned this chain saw from new. I can no longer get it to tick over. I get it to start, but have to keep my finger on the trigger to keep it running. I’ve cleaned the air filter, tried it without the air filter, put clean fuel in. I’ve even tried running it without the chain bar & chain. It just dies when I let go of the throttle. Maybe the carb needs adjusting, but it had never been touched from new as there was never any need.
The thing is the PDF instruction manual says do not adjust it yourself as damage can be done
From manual...
CARBURETOR ADJUSTMENTS
Your carburettor is equipped with limiter
caps. Carburettor adjustment is a complicated
task. We recommend that you take
your unit to an Authorized Service Dealer.
Damage will occur if you turn the needles beyond
the limiter stops.
From manual...
the limiter stops.
