Wendelspanswick
Hopefully @HughF can provide some insight as I know he lives off grid.
Getting to the stage where we can start using the barn but two hurdles to overcome are there is no mains power or water.
I'm going to use rainwater collection for everything but drinking, using the roof runoff and passing it through a sediment tank then a slow action sand filter into an underground storage tank then pump it up to a roof space tank. This will be used for washing etc.
For power I was going to stick some solar panels on the roof, should be able to get a 6kw array on the roof.
For the rare occasions (sic) when the Sun fails to make an appearance I have a 15KVA PTO generator which can provide a 63 amp 240V supply plus I also have a small 3kva Honda generator.
I really need to come up with a system to store the power so I need a battery array and some method of controlling the inputs and outputs.
What batteries to go for, old tech or new?
How to monitor and control it all?
Reading up on off grid solar they seem to talk about either 36V or 48V systems, do you then transform this down to 12V for a lighting circuit or use an inverter to produce 240V?
Any info gratefully received.
