Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
This is @brewdexta aka Andy's Fixed Steady. Broken before he took ownership, the piece long lost. He whittled a bit of qtr plate to suit, I did the gluing.
1.6mmm Multistike tungsten
10lpm
On the pedal so around 50-80ish amps
1.6mm Sif No8 rod.
First a few tacks
Problem was the torch head wouldn't fit inbetween the webbing so I had to bend the tungsten a little, I fired it up on the bench and then quickly bent it with some grips. Had to turn to gas upto 10lpm for 5.
Then the tedious task of weld a bit wait a bit
weld a bit....
You could hold your hand on the part almost straight after each stitch the temp was so low. Waited untill it was cold before carrying on with the next.
10lpm
1.6mm Sif No8 rod.
First a few tacks
weld a bit....
