Thrashsmith
Hi folks,
Is there a dark art to drilling slotted vertical holes in masonry, or is it just a case of drilling a series of vertical holes? Nearly all of my clients have period buildings with old red brick piers, never block work and rarely new brickwork.
I have attached a doodle of a hinge pin forged from 25 x 8mm flat bar. I have also drawn in a couple holes in the wing(?) for resin to key into. It could even be 25 x 6mm now thinking about it.
Is there a rule of thumb for oversizing holes for resin?
Cheers
Cheers
. I often use taper roller bearings under the gate hinge line and a ball race at the top. One needs a solid lintel under, or cast a footing. System gives very low opening forces on big and heavy gates. Might find a photo of one if I look.
