Where would i get a 100k trimmer pot suitable for it? Maplin maybe?
Wow that was quick only taken 3yrs and a few mths !! resistors are unidirectional you should be able to work out where the resistor needs to go in circuit simply with a multi meter, so when you screw the trim pot, if it increases or decreases, legs 1-3 are usually total resistance ie 100 ohm , then 2 is the adjusted leg which goes up or down depending on the required resistance.I've done the capacitor/diode/relay mod to the wire feed circuit
