Can I ask what For?
not if he uses nutlinkYou can get split sprockets for go karts so what about chain, rather than belt, drive ? Problem with a split pulley is he'd still have to remove prop shaft to attach a standard type drive belt. At least with chain you could have split link
Another idea is attach a small rubber tyred wheel to the alternator and have friction drive on the prop with a spring that kept the tension.
I understand your concern re stuffing gland but it would surely go closer to the Gearbox to keep it all out of the bilgesI think you'd need a lot more tension than with a belt. Depending on the type of stern gear this could side load the stuffing box/shaft seal unacceptably.
Ahh, I see a ships shaft generator! Just wondering why he wants to use the shaft instead of the engines belt drive?certainly can.
He wants to run an alternator of the prop.
other point what happens to the alternator when the props in reverse anyone does it upset the coils diodes etc
DIODES ?? it makes no difference still charges either way coz its ac and recified to dc so they have no coping to do al you need is a none directional fan!The diodes will cope. Alternators are usually 3ph that is then rectified.
