Screws no good Resin fix stud or through bolts. Concrete screws? Save them for doors and windows Imo
good concrete screws are fricking awesome
I removed a window a couple of weeks ago, didn't even have long concrete screws in it, battery drill didn't want to shift two of them, so I grabbed a ratchet... and snapped a teng t30 torx bit :-0
I've got loads of good, heavy stuff held up with them, if it's important stuff, buy decent ones and make them as long as you can... you're not going to pull a 130mm concrete screw out of the concrete, so only way to break it would be to snap it, they're 6mm ish diameter ? - imagine trying to snap an m6 bolt out of the ground with a claw hammer... it's practically the same thing
say he wants 3 compartments at 100mm wide each, that means the rack thing will be about 400mm wide ? (3x100mm gaps and 4x25mm box section uprights) the wider base makes it stronger too
