Well, cable arrived courtesy of a brilliant ebayer (4siteonline), and it was a bit bigger than the original because of the swa and extra insulation but the cable pixies were with me on this occasion, soldered the two ends together after twisting and lots of tape to taper the joint in and we (me and my good lady) just got done pulling in the section running under the house, her feeding and pouring cable pull lubricant in, and me on donkey outside dragging. It snagged at one point and we had to work it back and forth a few times, but it came good in the end and the SWA outer isnt damaged.
Now just got to drag it in all the way under the yard now, but I can dig that bit up. Just having a brew, its hard work manually pulling a cable that big. Then I'll be er... busy in the shed for a bit catching up on lost time
) is what looks like tough pvc but in fact tears along it's length very easily - it is thickish walled (perhaps 2.5 mm) and about 30 mm id smooth and black - I have the end of a roll left from running cable to the front gate.
