Hi all,
First of all I am no welder, but I am working on something that may need a specialist pressure vessel. As I did my apprenticeship with CompAir years ago I am well aware of the danagers of compessed gasses and what can happen if a pressure vessel should fail, so I am not about to do a back street DIY job.
I need to be able to put a device that I am developing under external pressure. This means that I will need access at one end of the pressure vessel. Further more there will need to be at least two isolated electrical connectors to allow electrical connectivity to the device under pressure.
As you can see it is a bit unusual so it would be expensive to get one built from scratch and my name is not Donald Trump
. This really gives me only two options. Find a second hand one, possibly an ex-process pressure vessel or get a standard pressure vessel modified.
Any leads or advice you may have would be much appreciated.
Thanks
. This really gives me only two options. Find a second hand one, possibly an ex-process pressure vessel or get a standard pressure vessel modified.Any leads or advice you may have would be much appreciated.
Thanks
pure oxygen
It's a bomb unless you can be 100% sure of no oil.....Only use an inert gas,
