Remove the felt and install a membrane instead, many makes around and you can bond them down.
i just tin sheeted mine box profile stuff seconds and made the ends, ridge tiles, out of the same sheets
Never used membrane, can you put it straight down with nothing on top ?Remove the felt and install a membrane instead, many makes around and you can bond them down.
ops wind getting under it, you can bond it down with petroleum based glue, or you can use a dedicated glue which is expensive, most people use Unibond or similar.
