sardine
- Buckinghamshire
I need to fill a 6 meter long 1 " bore steel or iron pipe with something that will set and block off the pipe. Its an underwater keel cooling pipe on a boat, which has corroded through and has been disconnected, the boat is not going to be docked, and if its left parts of the system which are inaccessible under the floor are 22 mm copper and might freeze and then burst and leak into the boat.
Something liquid, will set , is cheap, and will fill the whole pipe by gravity or easily pumped in ?
Over to you.
Over to you.
