The welding leads on the old oxfords fit on with a large ring terminal held on with a bakelite knob, unlike most modern machines that use the bayonet type Dinse connectors.
I'd take some decent heavy duty car jump start leads - croc clips onto terminals and rod in the other, saves buying leads if welder not bought
(my jump leads are home made with 50mm² cable!)
This is my oxford 300 arc set.
Does its performance justify the size and weight involved?
I'd have said - "Does its performance justify the size and weight and cost involved?"
I normally take cost into account
I do! And I said that in another thread...somewhere...10/10 for having a go. But it's not, it's somebody trying to challenge ALL conventional wisdom & technique...from Aldi, Books & t'Inernet; as I said, take the dog outSteve, you have to admire George for his perseverance
George, you are a hard nut to crack! (a true Doubting Thomas, no less)
The answer to your Oxford question is Yes! New or used.
How many people have to tell you that Oxfords (or Pickhills, or Cytringhams) are good welders before you will believe them? Go and buy one if you are not convinced, and see for yourself. At least if you don't like it, you can sell it on for what you paid for it.
I was simply trying to ascertain what it is, exactly, that makes them so good
