This must be one of the quickest, easiest and (so far) most successful things I've ever made. I removed the secondary winding from a brand new arc welding transformer and replaced it with 4 turns of thick copper welding cable:
First tests produced so-so results but at least it didn't blow the 240V 13A fuse. Then I realised that I'd left the transformer shunt on the minimum setting, like for the original 45A arc welding output. Once I pulled out the shunt, it was then on the 100A arc weld setting, effectively. This is the transfomer from a low cost, quite small arc welder. But my new windings produce only 2.4V so the spot welding current is probably now nearer 2000A.
I succeeded in fusing together two sheets of car body panel steel (thickness about 0.8mm x 2) with one spot weld. I tried to pull the two sheets apart with pliers but I can't, so it seems pretty strong. Once I get a joggler I hope to use spot welds to form the initial 'tack' joints, followed by a continuous seam (arc) weld in order to satisfy any MOT requirements. I'll also see if I can use spot welds to do a butt joint.
There is negligible new metal above the surface. The weld seems neat and tidy compared to some conventional welds. Many of the marks on the metal are from earlier experiments on the same pieces of scrap metal.
Here's one side:
And here's the other side:
WARNING - yes, there are all sorts of risks with this project. I hope I can manage those risks but I admit I'm no expert as far as high power electrical devices are concerned. I'm not suggesting that anyone else should try this out. Danger of death, etc. I take all sorts of precautions (not fully described here) but I can't say they're sufficient.
Here's one side:
Just hope you don't get a fault with the insulation on that transformer. It was in a case for a good reason![]()
Good on you for experimenting george,just mind those open wiring bits an pieces!
