So for migging gates n railings what amperage do you need? no bells and whistles ,but enough guts to do the job without releasing the special smoke which holds the special sparks in it..For 'keep the dog' in gates and railing you would need a 180 amp machine as a minimum, you can get away with a bit less but it involves experience and preparation, ok for your own stuff but not ideal for customers if you get a weld fail that causes injury, the no win no fee vultures will be knocking at your door.
For 'I want the best on the street' gates and railings you need a much more powerful machine or an MMA inverter.
For both types of gates and railing you will probably need to up your electric supply if it is not already capable of running the bigger machines.
I have made railings using a 135 Clarke, 25mm box frame with 12mm bars with no problems, now obviously the experts will say they are not welded to full penetration etc etc and I will agree 100%, I will also guarantee it would take a hell of a big hammer and a lot of sweat to break apart and it would bend long before parting.So for migging gates n railings what amperage do you need? no bells and whistles ,but enough guts to do the job without releasing the special smoke which holds the special sparks in it..
