Arclikeharrypotter
- Northampton
In short by not weaving you reduce heat input.
This in turn reduces the grain size in the microstructure. Smaller tighter grain size makes a tougher weld and doesn't effect the toughness of the parent material as much as if you had a high heat input.
A second and a third run refines the grain structure even further.
Grain growth I believe is the term used when describing a welded joint that has been put in with a lot of heat input. And it usually results in low toughness when charpy results come back.
A lot of stringent mma wps's actually state a run off length. Ie for every 400mm of rod burnt off you should of deposited 250mm of weld length with a tolerance either side.
This way there is control over travel speed and there for control over heat input.
Very interesting. I know that when you are producing a wps every run will be timed. Possibly not on all but those I've witnessed have been.
