DAPPH
as dyslexik as I'm daft
I'm seeking tips advice as to how to go about cutting up a 40 foot one way used steel cargo container .
Into lengths that will fit on a 1.5 tonne Ifor Williams 4 wheeled trailer that is seven foot wide at the side boards with a cargo space 9 foot or so long .
We have access to a 10 foot legged tripod ,a 2 tonne chain hoist & a lot of 5 tonne or so long ratchet straps & some decent slings .
I belong to the Amman Valley mens shed group .
We may be in line for a job of getting a clean used once such container . However there is no way we can get it in place down a 10 foot wide cinder track that has a heavy duty gate of s 11 foot wide due to the entrance being far too tight to turn or reverse into with it on a whole 40 foot length plus the towing vehicle & trailer .
My thought are .... weld small locating plates with a MIG welder in the right places . So once we've plasma cut a drawn guide line & cut along parts of it cut we can weld drilled out 30 mm angle irons to the guide plates & draw bolt the halves or thirds back together once the whole container is cut through . The finished container will sit on a crushed compacted rubble base then on top of a lot of railway sleepers .
Then re Mig weld them all along the cuts to make the " container shed " Fully welding all the outer faces & the floor between them on to the walls , roof & floor of the container before giving it a durable spray paint job .
Any suggestions as to how to organise it , ways to proceed & things to watch out for will be most welcome .
Currently we have a small 80 psi compressor ...no plasma cutter but I do have my tig helmet & gloves Plus a 9 inch & a 4 inch disc cutters each with a full edged tungsten & diamond blade , a sabre saw with 6 inch steel blades & a 2.2 kva sine wave genny & a 25 mtr 20 amp extension lead . Plus plenty of wood laths & battery drills & some steel strips 6 mtr long by 3 mm thick & 50 mm or so wide . One 6 mtr length of 30 mm 90 % angle iron taps & dies nuts & bolts etc
