I found this a while ago which looks good.
There's a couple of videos following t but they should be easy enough to find.
No i will take the other rest off and make something no where near as good as this .So the idea of that is to further support the current rest that is on there?
Good Job .This evening I have mostly been using a chain block, hilift jack, lots of bubble wrap, few miles of pallet wrap as pics show
Good Job .
Cant wait to get this unwrapped.
The question is will i be able to get it together with out any lifting equipment?
Thanks Chris you've done well. Should give you a bit of room in the garage to buy something else .Yep, I used the chain block to lift it onto the pallet and the hilift jack to tip it over and lower it down. Probably could have done it without the gear if I'd had help but was late back tonight and was on my own.
Headstock and other stuff you can do without assistance
Be careful when unpacking as there are nuts, bolts and other small bits wrapped up in plastic bags and bubble wrap
And, the fastenings seem to be a mix of imperial and metric
rub chalk on a file,
