Is it an issue if you fit a slightly bigger rated cap?
get in touch with facon here send them that picture and the may be able to identify it from the model number, the didgits you thought may be the number 30 i would say is wrong, what you think could be the number 3 looks nothing like the 3 at the end of the model number so dont rely on that
My small compressor has a 25uf fitted, I only know this because the vibration caused the one of the teminals to break of a few days ago, I managed to pare back the plastic casing just enough to expose enough of the broken terminal to solder it back together, while it was off I took a photo with a view to finding a new one.
I'm not exactly sure, I'd have to check it on monday, from memory though 2.5hp rings a bell.What size/hp is the motor??
My one is 3hp
im wondering if the lack of clarity is intentional, ive looked at other facon capacitors and the 5th and 6th digit always seems to be the same as the cap value but on yours there is a blank where the 5th digit should be
