ajlelectronics
- Gloucester, England
I currently feed the compressor to regulator pack with a rubber hose, could be 3/8" or 5/16" bore, probably the latter. I am going to replumb from its new position outside and intend to use copper. I have a few questions:
22mm or 15mm? I had intended 22mm but maybe that is over kill? Distance is 2m up, 5m across the ceiling and 2m down to the regulator.
The lever valve as fitted to the compressor by MM is likely to have a standard thread (15mm compression)?
The compressor is a heavy beast which will be unlikely to walk. Can I couple it up with a rigid pipe, or must I use a flexi? If so, where do I find a flexi that will run at 10 Bar all the time? Plan B, how about a coil of 15mm, but then how do I form a nice tight coil without a kink?
in 10mm plastic pipe and even had water freeze in winter partially blocking the pipes. I have 2 3hp compressors driving my blast room so I'm putting plenty of air through.
