its nice to see that gate up and painted with a precoat on itNot so much what I made today, but what I did today....
Test fitted the gate to establish where the catch tab needs to be - progress has been delayed by a) builders working round the house for almost 2 months [] re-harling, b) my not being well with a bug [twice] and needing a/biotics to shift it, and c) the weather being too cold and damp to sensibly have a go at painting it.
It's coming along...slowly
That is an outboard motor stand. Well it could be !I knocked this up, its to mount a retractable hose reel on, a proper industrial one not a plastic diy job.
Stainless steel angle, tigged as usual
You have a chicken in your workshop!
Shame it wasn't brass, could have found some mug and sold them golden eggsbe interesting to see the shiny metallic finish on some of those eggs though!!
Thank you..everything I do I use only a angle grinder. Files.and welder. Sometimes the bench grinder..electric drill. But with basic tooling you can make most things.Spencer you are a bang tidy fabricator fella.
Finished. Blade needs to be replaced as it has bean badly ground in the past.
It taken and edge, so the plane is set up for fine finishing on hard woods.
The parts were not that badly rusted, but a few hours in the heated de-rusting tank.
From that to this.
The wooden handles needed 3 egg cups of linseed oil to get them buffed up.
You mean beams not columns and why are you using UC'S for beams?Made 13 flooring columns for a mates barn, 203 x 203 x46 U/C with 12mm end plates to bolt into the uprights.
Gave the ESAB 400 a run, mate tacked the end plates on and I ran the weld around them and over did it, still suffering.
Installed all 13 in his barn as the uprights were pre drilled and it was a quick lift with his teleporter into position while I lined them up and bolted them in, all he has to do now is put the floor on top of them at his leisure for storage space in his barn.
