ajlelectronics
- Gloucester, England
Alloy expansion tank, found in my stash. Fits the intended position almost perfectly, but needs modding.
I have to plumb in a return line at the top right of 8mm. I have searched for bolt in spigots but must be using the wrong terms, so nothing coming up. What are they called? Would I be better advised to get someone to Tig a boss in?
The lower inlet port is 13mm. I need 16mm, ideally in an S shape, but could work with an elbow. No idea what thread it is, but the diameter is slightly larger than 13mm. 1/2" BSP likely as it is Chinese made?
How best to organise that connector? I don't really want to make it from copper soldered up, due to the appearance. It has to look like it was designed, rather than cobbled!
