rcx132
Philip
- London, UK
My Sealey 150 L compressor has a soft start system. When the tank gets to 150 psi the pressure switch turns off the motor and then it purges the air out of the pipe between the motor and the tank. This means that when the motor starts again then the motor has a soft start.
The system relies on a special pressure switch that has the mechanism to purge the air hose each time. Sealey charge £70 for this switch, compare to £20 for a generic switch. I use my compressor twice a month, I've had it five years, and I now need to buy third such switch. I haven't looked what's broken yet, maybe it's fixable.
Can anyone think of an alternative to using this switch. Maybe something fancy like a solenoid valve that activates each time the power is cut off to the motor.
