gaz1
- westyorkshire
with your height you could jack up the lathe to the required height
as the ml7 and the ml10s both can use stands underneath them to adjust them you could make yours out of a triangle shape cut the top off and sit it on a plate or prebolts drilled through the plate
the original stand would collect alot of swarf before it needs to be cleaned up or you could add a lip for the oil to collect and be repumped back up to the work piece
