powderblast
- Hull, UK
Hi all i have just purchased a band saw and i had to install a new blade because the machine did not come with on (snapped on the previous owner)
I purchased a blade from a company of ebay called misterrbandsaw, its a 8-10tpi the full machine works fantastic however i have noticed two issues one is that band saw head appears to judder after inspecting it appears to be the weld joint running through the guide pads, is this normal also the blades cuts great on thick material but when i try to cut hollow box section it vibrates look at the pics to see the cut quality.
I was wondering could these two faults be down to a poor blade and possible wrong tpi for the material.
I think i need a blade with more teeth but unsure as this is the first band saw i have ever used
