you dont say whats wrong with it just put in new oil any try ?
I doubt if you'll find one like that for £50. I repaired the pump on an old Bradbury Jackette using O rings, I bought a few Viton ones in varying sizes and got it working again but my old small jack was not having any of it when that packed up. I bought a jack from SGS to replace it but it is a bigger one than I thought it was going to be so I might get another smaller one to carry about. The one in your picture looks like my Bradbury, seals are available but they are not cheap.
Same as the one I have. Its a Yankee/ Sealey 3t jack AFAIK.
Hi, Be aware with the first (cheaper) one because it's taller may not go as far under the car and if it does you may not get any stroke on the handle to operate it.
Colin
With fast lift?
Do you know which model?
No, no fast lift/ "rocket lift".
Rocket lift has a separate foot operated pedal.
That one in the first pic doesn't appear to have the fast lift either.
I got mine for £114 plus 2 axle stands, foam mats, breaker bar and petrol can.
Same jack as this;
http://www.demon-tweeks.co.uk/tools-workshop/jacks-axle-stands/sealey-3-ton-heavy-duty-trolley-jack
Looks similar to the Viking ones sold by machine Mart etc in the past.
personally I would fix it as although its heavy it will last for ever.
Loads of fixing info on line. Next time I have something powder coated I am going to strip mine and have it done as its not much more cost and will last better than paint
