Maker
Most folk just call me; Orange Joe
- Keeler crater
But I took one apart anyway
It's a 2.5HP Briggs and Stratton off a rotivator, it had been skipped (Probably for a good reason
) so it cost me nothing, hence no great loss if I ruin it.
I got it all apart and cleaned it all easily but now I'm putting it back together I'm having trouble.
Firstly, I didn't mark the gears on the cam and crank shaft before I took them out so I don't know exactly where they meshed. There's a line scribed into one and a drill mark in the other which I assumed were the original timing marks so I put them back together with them aligned but I'm not sure that's right - The exhaust valve starts to open when the piston is about 1/8" from the bottom of it's stroke. Does that sound about right?
. Would it be acceptable to grind a teenie bit off the top of the bit that connects the cam lobes to the valve stem (No idea what it's called, it looks like a 4mm pin with a 13mm circular head, all precision ground, hopefully you can tell what I mean from that
Other than that it appear to be in very good condition. There's a bit of rust and it's caked in mud but nothing was seized or obviously worn.
I'll upload some pics tomorrow (Technically today now
I was thinking that was wrong but it's just occurred to me as I type that the crankshaft can barely be a few degrees away from the bottom of the stroke so it's not like it would be wasting a significant amount of energy that would otherwise be used so it makes sense that it should be that way.
The second problem is the intake valve doesn't fully close on the compression stroke, I can fit a 0.1mm feeler gauge under it
