I don't know if I am right to call myself an intermediate welder but anyway I have a question that I think belongs in this section. I am working on a vehicle, welding using the pause thin metal method on my Sealey 185 Supermig. I am working with 1mm sheet and usually use setting 2 or 3 with the wire speed at around 5.
The problem is that even when I consider the welder set up right and the weld seems good the wire is sometimes burning back to the tip. I then have to use pliers and twist the torch so the wire eventually breaks away from the tip and pushes through the tip again.
This is becoming more and more annoying as although it usually happens on the first contact it can happen during the pause method welding which can then upset my method and joint. I have read that this is normally caused by too low a wire setting. However, I wondered if there is any exceptions to this particularly with the thin metal pause technique?
