I'm crosses u can be naughtHmmmm
View attachment 93595 I think it was the rust holding the oil in
You sunk my battleship.......Sorry wrong gameI'm crosses u can be naught
your title says sump, the work done suggested sieveHmmmm
Hahaha, yep oxy acetylene, the burning torch is on the bench as I'd just swapped it for the welding torch, thanks for the complimentoxo nice bit of brazing there. oxy acet ??? just noticed did u do it with the burning torch on pre heat
It wasn't the 1.7 litre naturally aspirated isuzu diesel lump by any chance ?. My 3 year old Corsa with the same lump developed rust holes in the sump at the front of the engine, needing a welded repair. After 4 years the paint started peeling off the inside the sump blocking the coarse oil filter on the oil pump suction, losing all oil pressure in the process. Fortunately it blocked off a few miles from home & able to get it towed home. Luckily after cleaning the filter, no damage appeared to have been done. It ran onto 130,000 miles.I gas welded the sump on my daughter's first Corsa. It surprises me that something so covered in oil can still rot through.
It wasn't the 1.7 litre naturally aspirated isuzu diesel lump by any chance ?.RonA
Pop it round I will braze it upOne of me mates had a rusted out oil filter Screw on type too
Hmmmm
