Would this be ok to weld on until i make a welding bench?
If anyone has any ideas how i can secure it, the bolt holes don't line up.
Depending on what i'm drilling i may get a bolt in there but it does not give much movement.Turn the vice sideways 90 degrees
LOL
I suppose i could drop the table all the way down then it would not be such a pain to rotate.Well it's not a milling machine, one good bolt usually works, two becomes a chore (doable on your set up) anything more is seriously overkill.
I am assuming the table at least can rotate and you're not drilling anything over half an inch.
Good ideaNice job.
I noticed the cupboards don't go all the way to the back of the bench you could fasten some drain pipe behind then for storing long things.
