Charlie390
- Northern Ireland
Excellent thanks
Also it'll tow much better when empty if it has some weight to it.I've worked out it will probably weigh 220ish kg all together, so it will still leave a decent payload.
For the chassis I would go for 100x50 and lay it upright so that it's far less likely to sag than straight box section.
Pulled the trigger on this and I'm just back from picking it up. It seems to be a lovely bit of kit, tyres are barely scrubbed in and not cracked so I'd say it's no more than 5 years old at the most. Seems like it will hold a ton so it will be perfect for a small utility trailer. I got it for less than the price of a new braked coupling so I'm happy. He even threw in a set of mudguards
SAG !! he is talking a ton max, I dont think I would use 100 x 50 on edge, to even make a plant trailer carrying 3 ton ! for his aplication 50x50 is ample IMOFor the chassis I would go for 100x50 and lay it upright so that it's far less likely to sag than straight box section.
In fact Pete, some mass produced trailers dont even have a frame the pressed steel shape forms the 'frame' as a monocoque, and they easily carry a ton.I had a 1000kg (payload) 6*4 trailer a while back - the box frame was 50mm angle around the bottom with uprights and caps in 25mm angle (3mm stuff).
I do apologise from sharing an opinion on here, I shall in the future refrain from doing so and not go on personal experiences as they always seem to be wrong on this forum...
Yet again everyone knows best.
does the trailer have any suspension? like those rubber bushed semi-trailing arm things?
