.Hi Wozzaaah
Thanks for your advice. I used the grinder to grind away previous welding attempts that, once ground away, fell apart because they had no penetration. This is why I now have the welder turned up as high as it will go but as you can see I now get very high lumps of weld so I am not sure what is going wrong there. Maybe travel speed issue perhaps ?? I have no dea hence the post.
To run at 19.5 volts does this mean I need both switches on max as well as max wire speed?
Why/What is the black around the welds ??
I have many questions. Will give it another try at the weekend and see what happens.
I appreciate your advice
Ash
