monkeh
- Corby UK
Hi Guys,
So i finally managed to get a bit of 10mm plate offcut from a local steel supplier and some 40 x 40 x3 box to make a welding bench with.
I dont have much space so its only a little 580 x 690mm bit i got
Ive made a design but im not sure if its any good.
its upside down so you can see better. I did it like that so i can hang clamps etc on the side rails and the long runners are open ended so i can add extender bars if needed or add removable tools like a vice and grinder. Im just not sure if its better to support the top all round and then add bars as well.
Im not sure if i need to add supports between the legs lower down as well. The bench will only be 600-700mm high as ill be sitting on a low seat i have.
I only have just enough box section to make this design so id have to wait untill i can get more if i change it.
Thanks all
Thanks all
