lol yes mate...I dont know where the guy who fitted it picked up the feed for the lights. I am pretty sure he did not go all the way back to the trips.Have you checked all the easily accessible places first?
I have found some connection blocks. This is the one I think should be powering the lights.
It has no power to it.........I spent the afternoon taking the roof off pics later....
they will be till someone lays tiles or laminate floors over the boards. joints in walls need to be crimped if there buried and inaccessibleReg 526.3 "Junction boxes with screw terminals must be accessible for inspection, testing & maintenance...."![]()
This was 30 years ago. lolReg 526.3 "Junction boxes with screw terminals must be accessible for inspection, testing & maintenance...."![]()
The only thing I can think of is around 6 years ago my son drilled into the wall and it went bang.... but this was fine afterwards.Have you done any building works close by that could be something like a screw or nail through a cable, or anything moved for decorating that could of snapped a wire inside a fitting.
Is this lighting circuit covered by a RCD or RCBO or just a MCB/Fuse.
No mate. that's just it. they all seem to be supplying power to something.do u have a lighting cable back at db that doesn't do anything and u think its faulty and supplies the lights ??if so leave it disconnected and run a new feed to where u can connect to the known cables
If I did not already have a leak in the roof yes maybe.Ok I've been to the pub and I'm slightly ****** but is it only me that thinks taking up the roof is a bit ott?![]()
just this minute solved it......I managed to trace the wires due to the opening in the roof. Sadly for me it was a bloody fuse in a box I thought supplied the central heating in the airing cupboard.I'd be getting a sparky in.....![]()
I am fitting plastic hatches..I would be tempted to replace the joints in the roof space with something screwless and maintenance free.
Maybe wago.![]()
They can just blow( usually upon turning on) but my guess is when the bulb in the utility room went it took out the fuse. I stand to be corrected.Can you tell what caused the fuse to blow?Or do they just fall over with old age.......?
a lightbulb goes and blows themCan you tell what caused the fuse to blow?Or do they just fall over with old age.......?
