Hi everyone, I'm looking for some advice please:
Material expansion/contraction:
I have 3m lengths of 6mm mild steel angle that will make a continuous hand rail along the top of the cabin of my narrowboat. The cabin is of 3mm mild steel and roughly 14m long.
My plan is to tack the first 3m length in place in the middle of the cabin top, then fix it permanently with 3 or 4 inch beads (prob. 3 or 4 passes per finished bead) spread at roughly 300mm centres, alternating those beads between the inside and the outside of the angle, if that makes sense. The edge of the angle is prepped with a chamfer to aid penetration but limit the power so that I'm not blowing holes in the cabin. I was thinking of working from the center out.
I'll then butt the second and third lengths to the ends of the first fixed length and so on repeating the process, working towards the ends of the cabin. There'll be a gap of 3 - 5mm between the ends that I'll fill as a route weld once everything's had a chance to cool down.
The question is; will the 3-5mm gap be enough to allow for expansion and contraction? I'm afraid that if I go for a larger gap I'll not be able to fill it.
Many thanks in advance for any thoughts.
T
T
Sure does, don't think it can be avoided though. Not in the time I have available anyway.
