I'm going to build a box trailer similar to a tow a van shape but to suit my needs for motorsport but would like some advice on materials and welding. I need it to be as light as possible to be able to push it up a drive.
The spec will be 3.5m (11.5ft) long in total including the hitch, 1.5m (5ft) wide with with wheels outside of that. 1.5m high and a loading area of 1.5 x 3m ( 5 x 10ft) including the pointed front.
The initial plan is to make a box base frame from aluminium 50x25x3.2mm then make the uprights and roof frame from 30x30x3.2mm angle.
This will be laid onto a frame that the tow coupling, suspension units and mounting plates will all be welded or fastened to. I'm not sure if this shall be an 'A' frame shape or more of a T shape using the axle as the top of the 'T'
Because weight saving is very important I initially wanted to make the frame also from Aluminium but I was told that it will be prone to cracking welds bouncing around on indespension units. I would be better to make it from steel and then bolt the box frame on top of it. Is this true, and how strong is an alu weld compared with steel?
Has anyone done a self build?
