Tinbasherdan
Bodger in chief
- Bolton, England
Anything to do with the mod is a money wading exercise to a point believe me
There was a Police forensics car pound near where I worked which we sometimes used, part of the process they used was some kind of solution which became carcinogenic when exposed to high temperatures, there were a lot of mint, virtually new, top of the range cars in there (Range Rover, Mercedes, BMW, Jag) which where all going to the crusher, nothing at all was allowed to leave that compound (except to the crusher) because of that risk.
So you end up with a cubed car full of carcinogens, what happens to it then? Sell it to a third world country where there's no comeback?
I did the opposite once, working for a major agricultural machinery manufacturer. Over the years they had acquired a lot of companies and had marketing agreements with others. Their spare parts numbers were loaded into the system and assigned a new company number. The duplication was endless, we had five different sources for a standard H4 headlight bulb and still kept stock of yellow headlight bulbs for France. I saved a fortune by tracing it all and throwing the results at the purchasing department, as well as rationalizing the price list.A place I worked in the 90's decided spares should be stocked under internal part numbers rather than manufacturers part numbers so they cleared the shelves into a skip instead of re-numbering. I saw £000's of Telemecanique contactors, relays, sensors etc. just dumped![]()
We were smarter. Purchasing sorted out the cheapest supplier, even better since the order quantities increased, then we loaded the system with supercession numbers so as the stock of the old numbers ran out it shifted orders to the number we wanted to end up with until eventually the old numbers fell into disuse and if a customer tried to order one it would simply tell him the number had been superceded to the new one. Nothing was junked. The very idea!@julianthegypsy
My local agricultural spares place was the same. For some tractors they had up to 6 part numbers for the same part.
They simplified their part numbers etc, ordered new parts and binned 100 years of old parts.
In a previous life I spent a few weeks dogsbodying on an Admiralty Floating Dock while HMS Repulse was receiving a wash and brush-up before her last year of operation; once she'd been returned to the oggin I was trawling the dock bottom for detritus and dislodged packing from the docking blocks, and in amongst that I unearthed dozens of nickel aluminium bronze bolts, evidently discarded or dropped by careless dockyard mateys, buried in the doubtless highly toxic sludge of antifouling paint, rust and crushed crustacean shells. I still have one as a paperweight as most of them were 3/4" or 1" whitworth, presumably from through hull valves or something.I have a box of lovely bolts, each individually numbered, that were about to be skipped at a certain naval base, following a refit of a frigate. I asked why they couldn't just be put back into stores but no; once open the boxes could be 'contaminated' so any surplus had to be scrapped.
I'll find a use for them one day... maybe when a frigate needs a refit![]()
If you want a laugh, try drilling itIn a previous life I spent a few weeks dogsbodying on an Admiralty Floating Dock while HMS Repulse was receiving a wash and brush-up before her last year of operation; once she'd been returned to the oggin I was trawling the dock bottom for detritus and dislodged packing from the docking blocks, and in amongst that I unearthed dozens of nickel aluminium bronze bolts, evidently discarded or dropped by careless dockyard mateys, buried in the doubtless highly toxic sludge of antifouling paint, rust and crushed crustacean shells. I still have one as a paperweight as most of them were 3/4" or 1" whitworth, presumably from through hull valves or something.
As a rule I try not to throw anything away, a few work friends call my van "The TARDIS" for what I carry and salvage from old dead systems.
My best repair this year was on a fire system built in 1968. I know t is not compliant, it is not used as a main system but as a demonstration unit.
In my box's of spares was a signal line amplifier what fitted and allowed it to power up and work.
Yes, the main PSU has valves.
