I recently got a Clarke 130TE from someone on ebay. I have replaced the wire liner, swan neck etc (from weldequip) but the feed is still all over the shop.
I think the problem is the rollers. When I lift the top one the other one moves fine when I push the button but when I put the other one down the movement is intermitent and it doesn't seem to make much difference how much tension I put on the roller. It either spins and the wire doesn't move or I put too much tension on an neither roller move.
I cleaned up both rollers with a bith of cloth and some 800 grit sand paper and it made a little bit of difference but not enough to make the welder useable.
Can the roller be replaced? I put some wd40 on the top roller (the one with the tension thing) but I don't think that was a good idea as that one spins freely but doesn't move when the two rollers are on the wire.
I realise I have just posted a load of gibberish, sorry.
