slim_boy_fat
- Scottish Highlands
Washing machines, anyone know anything about them?
Mine, a Hoover New Wave Autowasher 1300 like so,
started leaking water all over the floor, so initially suspecting a leaking hose, I investigated and discovered it was the drain pump which had turned its toes up.
No great problem there, on to Google and a new pump sourced and bought off the 'Bay - should be with me by the end of the week.
Now, my question is this. This machine is 25 years old and still functions fine, the only things I've had to do are replace feed hoses and a drive belt. Back in those days, they were designed for cold and hot fill, as opposed to the modern machines which I understand require cold only ......?
Currently, mine is plumbed to feed from the cold mains supply only, but with two hoses to the machine through a Y piece.
Could I dispense with the hot feed hose and simply blank off the 'hot' connection on the machine and still have it function correctly? It'd simplify the plumbing and reduce the potential for leaks in the supply.
No great problem there, on to Google and a new pump sourced and bought off the 'Bay - should be with me by the end of the week.Now, my question is this. This machine is 25 years old and still functions fine, the only things I've had to do are replace feed hoses and a drive belt. Back in those days, they were designed for cold and hot fill, as opposed to the modern machines which I understand require cold only ......?
