Barlidge
- Langford, Bedfordshire, UK
well i finerly bite the bullet and ordered one..
O-FS-PS200ADJ
doing a few bits again in the bucket using the battery charger.
They are good value, you can also use them for plating
O-FS-PS200ADJ
Simple things can totally cock the process up. That's where having an ammeter on the setup comes in handy. If you don't see any current draw, you know either a connection is poor else something else is up. Most problems, if the setup is generally sound, are usually down to bad connections.
Wouldn't have thought that additional agitation would make much, if any, difference. If you try it though, let us know the results between running a pump and not.
Filtering the solution definitely wouldn't hurt, but isn't a necessity. All of the crap settles to the bottom of the tank when you're not running it, so it's out of the way as such unless you stir it up.
Hi, I need some help with electrolysis. I've been using it successful for few months but I want to make some changes. My free PSU had hissing caps and you can hear it down the road when it's operating. Like somebody is trying to steal your tyres. I will be replacing it with something else but I want to make the right decision without just throwing money to experiment. While I'm happy with my big tank now it only draws 2-3 amps from a 12v desktop PSU. The original plan was to get another desktop PSU but I want to be able to run more amps now. I want to be able not only to remove the rust after 24+ hours but also lift/soften the paint more easily. This is where this setup is struggling and I have to leave the wheel for days while I keep brushing every day the newly softened paint.
My question is, I'm going with a Universal Switch PSU and they are available in either 12v 5-40 amps or 24v 10-25amps etc This is what they look like http://i.imgur.com/PnekaW6.jpg So the question is should I get a 24v at around 20amps or should I purchase a 12v that can do 30-40amps (for my price range). I haven't heard people talk about this and I was wondering if anybody has tried it. I only heard positive opinions on people on the internet who are running 24v. Maybe it's smoother or maybe it keeps the high amps up. My desktop PSU was rated up to 12A yet it never managed anything above 2-3amps but that's probably on me due to my setup. Which is ok, I can always adjust that. Again the best opinion had come from people who used 24v car battery chargers set on Boost, or Fork Lift Battery Chargers which are very expensive....we are talking 3 digits now. I don't mind if there is extra heat, extra foam etc as long as the process is NOT QUCIKER but better. I often find hidden rust under the crust where a bit more paint has lifted etc. Need to take it out, brush it and make some holes for the electrolysis to keep penetrating further etc.
My setup currently at 2 amps has zero foam, it's cold as ice, it's effective but drops amps very quickly after it's been stirred up.
If you want to remove paint, use caustic soda as the electrolyte.
Gloves!
EYE PROTECTION!!!
it EATS skin!!!
12v 2a supply and patience
Yerbut rust removal as well.no need for the electric just a heated tank and caustic
He's making it look much harder than it is. That dull, grey, etched appearance is why I'm no fan of acid removal.Yerbut rust removal as well.
ah 2 birds one stone if its painted it shouldnt be that rusty
Rust will merrily form under a paint surface once moisture has some way of creeping in.I saw those videos pop up in my youtube feed.
Is it worth sitting through 45minutes of complaining about the epa/government/adverts for dvd lessons or could you tl;dw it for me?
I doubt the EPA would give a toss about vinegar with iron in it though. The current Tubal Cain has always struck me as being a bit half arsed and dramatic, from the odd bits of his videos which I've seen.
Don't get me wrong, some of his content is alright.
What got me was one last year where a good 10 minutes of a 30ish minute video was all about how the epa and the government were in cahoots with aliens and Garfield the cat creating a conspiracy of mind control over children and rabbits to take over the world and ban pliers because it's not fair that cars don't run on microwaves...
Well, I think that's what he said, I got bored and distracted and wasn't really paying attention.
