Dear Sean
It is there, but its in the last link; in the parts manual - not in the user manual.
michael
Hi Sean
I thought you ment info on the Squarewave as in the machine (it is called Esab DTA 200 Squarewave) - not specific info on the squarewave function. I that what you wanted?
What exactly do you need to know (I have some more papers on this machine at home, if its there I can mail you a file with it).
If the machine has been serviced the front panel might have extra buttons which does not appear in the manuals (mine as been retrofitted with a Scratch/LiftTig option switch).
You did find the front panel drawing, yes?
Michael
On AC it will if the balance is not 50%.Ermmmm torch positive you saying, nope work return + torch -, positive on the tungsten will just fry it.........unless your talking A/C then its not going to make any odds
Hi Sean
Sorry to have caused confusion. There is two functions absent on this machine:
Wave balance (how much goes which end)
High Frequency (how many HZ)
The HF frequency is set by a spark plug distance in the front left hand inside of the machine. The balance is fixed 50/50 and I cannot identify from the board layout where inside the machine it can be adjusted so I asume it is fixed.
Kind regards Michael
