If you are doing 70 in the outside Lane and you need to boot it to get past quickly it will often go to limp mode leaving you up ×÷=%_ Creek without a paddle.
Also at low speed if you boot it to pull away off an island it drops to limp mode. An ignition turning off and on puts it back to normal....but no codes are left.
Sticky variable vane turbo? Boot it and it produces too much boost and the ecu thinks there is a fault? Does it start to accelerate just before it goes into limp mode?
