Pete.
- Kent, UK
I needed to get the wheel off my daughter's VW today but the locking wheelnut adapter was nowhere to be found. It's usually kept in the car so very strange but we turned it inside out and didn't find it. So I decided to make one.
I counted the splines and made my best efforts to measure the diameters considering the bolt was deep in the well on the wheel. Then I had to find something for indexing to cut the splines on my lathe. Turns out I had a gear tooth cutter with the correct number of teeth so I used that.
The cutter has a 1" bore and I had some 1" BMS rod so I put that in a collet and knurled it to raise the OD somewhat. Then I tapped the cutter onto the knurl to grip it and found a couple of bits of cast iron to rudimentary indexing.
I turned the spline OD in the bar, machined a relief groove then made a tool to cut the splines. It's just a normal lathe bit ground 45 degrees each way to make a 90 degree cutter. That was put in the holder on it's side. Once it was set up all I had to do was use the cutter with the lathe motor turned off, all the cutting being done by hand-cranking the saddle up and down using the cross-slide to make a series of 5 thou cuts until I got it to depth.
Once it was cut I parted off the bar and welded it into an old 1" socket. After a couple of false starts and a bit of relieving with a 5" grinder I was able to bash the home made tool into the locking wheel nut and remove it easily.
