supermotobloke
Background:
No welding experience to speak of but making a little progress through trial & mainly error with mild/stainless.
After some basic information, and some base settings for a variety of aluminium (and s/steel if you feel inclined) welding please. Looking for what has worked in real situations. So tungsten type, amps, gas flow, metal prep etc
Equipment:
New Jasic JT-200D - PureShield Argon - Torches for 1.6 & 2.4mm - Foot pedal
First - has anyone any experience of this welder? Have read the manual, and it may as well be in Latin. Tells how to change settings but not how it effects welding.
Totally digital this setup. For steel torch is in negative socket, earth clamp in positive socket. Tell me this is correct!
Control panel allows stepping between DC and AC/DC modes. Is this all i have to do, or must i switch the leads around for AC/DC use?
Have been degreasing and then aqua blasting parts to prep ready. Do i need to still clean with a stainless brush & acetone? Could the aqua blasting cause contamination? Thinking of silicon debris impregnating the surface perhaps?
Situation 1.
Engine cases, rocker box covers, broken cylinder head fins etc and the like. All will have been exposed to oil at some point and showing pitting and signs of corrosion. Put a torch to these type parts and oil erupts - any suggestions?
Situation 2.
Clean or new aluminium of varying thickness up to perhaps 5/6mm
Equipment:
Situation 1.
Situation 2.
