trouble I find with them wearing glasses they make you rglasses steam up when its cold and u breath out even though the masks have a valve in themPrice isn't an issue, need one that can be worn with glasses, did see one on utube that was a"soft" material but remember what video it was on doh!
Cheers
How much was it and do you have a link please..?I just picked up a new mask with replaceable filters. The price was a bit scary but I have been going through at least one disposable one a week at over a fiver each.
The filters in the new one are said to be good for a month in most conditions so if I get even half that my costs have halved.
It certainly seals better ( you check by blocking the out valve and exhaling) if you have leaks on the out breath then you need to work on fit
Best of all its made here in the UK in the same County of Lancashire
Got a pack of ten filters so will be using it about a year
About to go melt some zinc off some steady rods ( threaded stud keeping two parts locked from distortion during galvanising) . Will be handy but I will also be outside with a blower on
You can get glasses modded to fit your snout with a mask on...the silverline foam pads for the nose are spot on as a glasses wearer no steaming of glasses tried the other ones and they always steam up one other thing you need them to be used with no beard on your face
havent found a rubber one yet that i can use with glasses as they do my head in on a few models that ive used
